[postgis-users] how to identify the_geom that cause :RelateOperation called withLWGEOMCOLLECTION type
Ghislain Geniaux geniaux at avignon.inra.fr
Mon Dec 8 10:29:25 PST 2008
On Linux  :
POSTGIS="1.3.1" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS
(1 row)
On Macos
  POSTGIS="1.2.1" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS
(1 row)
same result with the two platform and postgis version.
Thanks.
Le 8 déc. 08 à 17:53, Paragon Corporation a écrit :
> What does
> SELECT postgis_full_version();
> Return
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Ghislain
> Geniaux
> Sent: Monday, December 08, 2008 11:03 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] how to identify the_geom that cause
> I've no collection. It's looks like a bug.
> Moreover my table is very large wiht more than 500 000 geometry and i
> found no solution to identy the wrong geom.
> Here you can see the query, with the same result on different
> plateform (LINUX DEBIAN, MACOS, with GEOS 3)
> otm=# select distinct geometrytype(the_geom) from ZS2c;
>   geometrytype
>   MULTIPOLYGON
> (1 row)
> otm=# select distinct geometrytype(the_geom) from bd_dispo_finalc ;
>   geometrytype
>   MULTIPOLYGON
>   POLYGON
> (2 rows)
> otm=# create table info_nonvoue1 as
> otm-# select b.id_parc, z.niv from bd_dispo_finalc as b, ZS2c as z
> otm-# where z.niv=1 and intersects(centroid(b.the_geom),z.the_geom)
> and b.the_geom && z.the_geom and isvalid(b.the_geom) and isvalid
> (z.the_geom);
> ERROR:  Relate Operation called with a LWGEOMCOLLECTION type.  This
> is unsupported
> otm=#
> Le 8 déc. 08 à 13:32, Obe, Regina a écrit :
>> Many of the GEOS relation functions do not work with collections.
>> You must have a geometry collection in there somewhere or its a bug.
>> Also which relation function were you trying?
>> To figure out the type of your geometries, run
>> SELECT *
>> FROM sometable
>> WHERE GeometryType(the_geom) = 'GEOMETRYCOLLECTION'
>> Nicolas Ribot
>> Sent: Monday, December 08, 2008 6:22 AM
>> Subject: Re: [postgis-users] how to identify the_geom that cause :
>>> I have an error with some geometry that cause : "ERROR Relate
>> Operation
>>> called withLWGEOMCOLLECTION type".
>>> All the geometries seem clean (valid, non empty, closed, only
>>> POLYGON,
>>> My question : how to get information of which geometry cause the
>> problem ?
>>> Is there a way  to have information about the geometry during
>>> postgis
>> is
>>> working on a  SQL query ?
>>> Thanks.
>> Hi Ghislain,
>> What the query that failed looks like ?
>> The message is telling that one geometry has an invalid type.
>> In your query, you could try to ask for ST_GeometryType(geometry) and
>> a geometry identifier to see which geometry has the wrong type.
>> If you perform a spatial operation, it is possible that
>> geometryCollection is produced.
>> You could maybe split your query into smaller block to see where such
>> collections are generated.
>> Nicolas
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
> Geniaux Ghislain
> INRA SAD Ecodéveloppement
> Site Agroparc
> Domaine St Paul
> 84914 Avignon Cedex 9
> Tél : 04 32 72 25 64
> Fax : 04 32 72 25 62
Geniaux Ghislain
Site Agroparc
Domaine St Paul
