[postgis-users] Help with query
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Wed Dec 10 06:07:33 PST 2008
Mark,
This could be either a mapserver question, or a postgis question
depending on the solution you chose.  I would say the following
(untested code):
Mapserver:
-          define 3 layers, 1 for each concentric circle using your 1 dd
circle as the template, with duplicates of 2 and 3
PostGIS:
construct a query which will return 3 results for each point in your
set, using a UNION, and altering your gid to be a decimal with .1,.2,
and .3 appended on the end to insure a unique gid, something like:
DATA "the_geom from (  (SELECT buffer(geometryfromtext('POINT(' ||
(%mapx%) || ' ' || (%mapy%) || ')',4326), 1) AS the_geom, (gid::float8 +
0.1) as gid FROM kbapoly) UNION (SELECT buffer(geometryfromtext('POINT('
|| (%mapx%) || ' ' || (%mapy%) || ')',4326), 2) AS the_geom,
(gid::float8 + 0.2) as gid  FROM kbapoly) UNION (SELECT
buffer(geometryfromtext('POINT(' || (%mapx%) || ' ' || (%mapy%) ||
')',4326), 3) AS the_geom, (gid::float8 + 0.3) as gid FROM kbapoly) ) as
myquery using srid=4326 using unique gid"
This PostGIS query assumes that mapserver will accept a floating point
as the unique identifier, rather than an integer, and I do not know if
that is acceptable or not.  Once again, probably more of a mapserver
question, when you get right down to it.
HTH,
r.b.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of mark
balman
Sent: Tuesday, December 09, 2008 11:53 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Help with query
Hi All
I am trying to create a query that uses a mouse click to get coordinates
(from mapserver) and then features within a specified distance are
selected and displayed in different colours. The query I have at the
moment works well, however, the problem I am trying to solve is how to
indicate these distances with concentric circles around the coordinates
from the mouse click. Is this do-able? My query is as follows;
DATA "the_geom FROM (SELECT intname,the_geom, gid, distance(the_geom,
geometryfromtext('POINT(' || (%mapx%) || ' ' || (%mapy%) || ')',4326))
AS dist from kbapoly) as myquery using SRID=4326 using unique gid"
At the moment I define the distance from the CLASS EXPRESSION so I have
3 classes
1)  EXPRESSION ([dist] <= 1)
2)  EXPRESSION ([dist] >= 1 AND [dist] <= 2)
3)  EXPRESSION ([dist] >= 2 AND [dist] <= 3)
(distance is decimal degrees)
I can create a buffer around a mouse click on the map using the
following query
DATA "the_geom from (SELECT buffer(geometryfromtext('POINT(' || (%mapx%)
|| ' ' || (%mapy%) || ')',4326), 1) AS the_geom, gid as gid FROM
kbapoly) as myquery using srid=4326 using unique gid"
What I am struggling with is how to combine these two queries if this is
possible. So I can display three concentric buffers at 1, 2 and 3
decimal degrees around the selected features.
Any help or advice would be really appreciated.
Thanks in advance
Mark
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081210/b70d9ea5/attachment.html>
