[postgis-users] Changed bahaviour of PostGIS confuses MapServer
Ivan Mincik ivan.mincik at gmail.com
Mon Dec 15 12:10:34 PST 2008
On Saturday 13 December 2008 18:13, Paul Ramsey wrote:
> Yes, Peter, I think it should call for a quick 1.3.5. Mapserver users
> are a huge contingent of PostGIS users, and anyone with a LINE layer
> now has a crasher. 1.3.5 should come off the line ASAP. There's always
> more version numbers, IMO.
> Can we have a quick vote on 1.3.5 release-from-branch, no-waities?
I have applied the patch, recompiled and changed liblwgeom.so to new. I hope this is enough, I do not need any changes to database.
I also vote for quick  1.3.5.
Ivan
> +1
> P.
> On Sat, Dec 13, 2008 at 1:25 AM, Peter Hopfgartner
> <peter.hopfgartner at r3-gis.com> wrote:
> > Mark Cave-Ayland wrote:
> >> Peter Hopfgartner wrote:
> >>> Dear MLs,
> >>> sorry for cross-posting to both, PostGIS and MS, but seems to rtouch
> >>> both.
> >>> I've tried to install PostGIS 1.3.4 on a CentOS 5 server with MapServer
> >>> 5.2.1 and PostgreSQL 8.2.11.
> >>> the command:
> >>> shp2img -l prova -e 1587541 5116731 1591730 5120008 -m prova.map >
> >>> ../../public/technet/test-<pgis-version>.png
> >>> with 1.3.3 gave the result shown in figure test-postgis-1.3.3-4.png (a
> >>> simple line layer)
> >>> Upgrading to 1.3.4 the picture became as in test-postgis-1.3.4-1.png, an
> >>> empty picture.
> >>> The relevant mapfile fragment is Mapfile.frag.txt, the SQL table
> >>> definition is e405.sql, all objects are MULTILINESTRINGs [SELECT DISTINCT
> >>> geometrytype(the_geom) FROM public.e405 results in MULTILINESTRING], the
> >>> geometry column is registered as MULTILINESTRING in geometry_columns.
> >>> Running the MapServer query:
> >>> SELECT
> >>> asbinary(force_collection(force_2d(the_geom)),'NDR'),common_uid::text from
> >>> public.e405 WHERE (tiplinapp is not null) and (the_geom && setSRID(
> >>> 'BOX3D(1587541 5116702.44897959,1591730
> >>> 5120036.55102041)'::BOX3D,find_srid('','public.e405','the_geom') ))
> >>> changed for better result readability into:
> >>> SELECT AsEWKT(force_collection(force_2d(the_geom))),common_uid::text from
> >>> by hand gives slightly different results, as shown in the attached files.
> >>> To make a long story short, 1.3.4 seems to better preserve the
> >>> MULTILINESTRING, but this seems to confuse MapServer.
> >>> Regards,
> >>> Peter
> >> Hi Peter,
> >> This is likely the known issue with MULTILINESTRINGs in 1.3.4 causing
> >> segfaults :(  The patch you need is very simple and can be found here:
> >> http://postgis.refractions.net/pipermail/postgis-commits/2008-December/000866.html
> >> if you can't wait for a 1.3.5 release. Please let us know whether this
> >> resolves the problem for you.
> >> HTH,
> >> Mark.
> > Should this issue call for a quick 1.3.5 release? If I understood this issue
> > well, everybody rendering PostGIS data stored as a MULTILINE geometry will
> > have this very same problem, at least with MapServer. I would guess that
> > this is quite a big share of PostGIS users that will be hit by this issue.
> > Regards,
> > Peter
> > Dott. Peter Hopfgartner
> > R3 GIS Srl - GmbH
> > Via Johann Kravogl-Str. 2
> > I-39012 Meran/Merano (BZ)
> > Email: peter.hopfgartner at r3-gis.com
> > Tel. : +39 0473 494949
> > Fax  : +39 0473 069902
> > www  : http://www.r3-gis.com
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
