[postgis-users] Shape import ERROR: floating-point exception SOLVED new Problem
Andreas Laggner andreas.laggner at vti.bund.de
Thu Feb 7 03:56:11 PST 2008
I threw away some bad looking attributes and now i have another Error
message:
ERROR:  unterminated quoted string at or near "'SRID=31467;"
LINE 1: ...ogley-Parabraunerde','930818','AAL','IAL','5','0','SRID=3146...
Someone an idea? I tried to change the projection file without success.....
thanks      Andreas
can anyone give me a hint what can be behind this error? This happens
when i want to import a .shp into postgis:
SQL Status:22P01
Detail:An invalid floating-point operation was signaled. This probably
means an out-of-range result or an invalid operation, such as division
by zero.
cheers      Andreas
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume des vTI
Johann Heinrich von Thünen-Institut (vTI),
Bundesforschungsinstitut für Ländliche Räume, Wald und Fischerei
Institute of Rural Studies of the vTI
Johann Heinrich von Thünen-Institute (vTI),
Federal Research Institute for Rural Areas, Forestry and Fisheries
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax:  (+49) (0)531 596 5599
E-mail: andreas.laggner at vti.bund.de
Homepage: http://www.vti.bund.de
Bundesallee 50
Bundesallee 50
