[postgis-users] 'Measure' 3D points on Polygons?
David William Bitner david.bitner at gmail.com
Tue Feb 12 15:59:23 PST 2008
Use AsEWKT(), astext() only supports 2D
On Feb 12, 2008 5:17 PM, <cgnicholas at alamedanet.net> wrote:
> Hmmm - this is interesting for providing one's own data directly in the
> query, but I'm still unclear how to actually get the Z value from a table.
> For example, I  am trying:
> create table ingest.sfterrain (gid serial PRIMARY KEY);
> select AddGeometryColumn('ingest', 'sfterrain', 'the_geom',
> '32610','POLYGONM', 3);
> insert into ingest.sfterrain (the_geom) values
> (GeometryFromText('POLYGONM((552161.99 4181849.92 7.31689,552174.81
> 4181862.97 7.31689,552149.81 4181887.53 7.31689,552161.99 4181849.92
> 7.31689))',32610));
> but when I select the row, I just get 2D points back, without the 'z':
> p9test3=# SELECT AsText(the_geom), GeometryType(the_geom),
> NDims(the_geom), ZMFlag(the_geom) FROM ingest.sfterrain limit 1;
>                                             astext
> geometrytype | ndims | zmflag
>  POLYGON((552161.99 4181849.92,552174.81 4181862.97,552149.81
> 4181887.53,552161.99 4181849.92)) | POLYGONM     |     3 |      1
> Am I inserting or selecting them incorrectly ?
> thanks in advance!
> Chris
> > Yes, it's supported.
> > test=# SELECT GeometryType(geom), NDims(geom), ZMFlag(geom) FROM
> >          (SELECT 'POLYGON((0 0 10 1, 0 1 10 2, 1 1 10 3, 1 0 10 4, 0 0
> > 10 1))'::geometry AS geom) AS foo;
> >           summary          | ndims | zmflag
> >                            |     4 |      3
> >  Polygon[ZMB] with 1 rings
> >     ring 0 has 5 points
> > (1 row)
> > How are you retrieving the vertex data?
> > -- Kevin
> > cgnicholas at alamedanet.net wrote:
> >> greetings - I'm wondering if the 'Measure' stuff works at all for
> >> Polygons.  I'm trying to associate a Z value with each vertex of a
> >> polygon
> >> (restricted to triangles for the moment.
> >> I AddGeometryColumn with a dimension of '3', etc, and am able to insert
> >> points that indeed have a Z. Things are GiST indexed properly, etc.
> >> But I don't seem to be able to retrieve the vertex data with the Z
> >> value...is this supported for polygons?  I'm trying to cast things to
> >> 'PolygonM', etc; still no luck...
> >> thanks!
> >> Chris
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080212/79a4fd68/attachment.html>
