[postgis-users] performance of intersects(a,b)
Willy-Bas Loos willybas at gmail.com
Tue Feb 19 01:36:47 PST 2008
that is, i'm not saying GEOS should work in the way that i describe, i just
mean it should know that it has a hit when one of the vertices intersects
with the other polygon.
Probably i'm seeing things too simple, but i guess never asking is the best
way to not get things improved, so i just ask stuff, even if it might be
silly.
On Feb 19, 2008 10:14 AM, Willy-Bas Loos <willybas at gmail.com> wrote:
> yes, of course. I use this example just to illustrate the case.
> What i really mean is: as soon as one of the veritices has a "hit",
> Intersects should return true and exit, no need to evaluate the rest (and
> Disjoint should return false).
> As i come to think of how this might work: the one whole polygon should be
> evaluated against each veritice of the other. I guess that this means that
> the number of vertices that have to be parsed is equal to N(a) x N(b). But
> once you've detected that the first veritice in "a" intersects with polygon
> "b", youre done (or should be).
> I'm not sure if GEOS works this way (compare all 10000 vertices with all
> the other 10000 verices), but the difference in performance between the
> previous query and this next one, kind of suggests that is does. (added
> pointonsurface(a)).
> select 'yes' as foo
>  from table1 a, table1 b
>  where a.gid=4
>  and b.gid=4
>  and intersects(pointonsurface(a.the_geom), b.the_geom);
> Maybe i should check the source code, even though i'm not a C programmer.
> Sry, my time is limited.
> WBL
> On Feb 19, 2008 1:54 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> > Right, this:
> >  select 'yes' as foo
> >  where a.gid=4
> >  and b.gid=4
> >  and st_intersects(a.the_geom, b.the_geom)
> > seems likely to a LOT less common than
> >  select 'yes' as foo
> >  where a.gid=4
> > and the latter gets far less benefit from the a.getpoint(0) =
> > b.getpoint(0) test, though the test would still be run on every
> > candidate.  I'm not sure where the cost/benefit inflection point is,
> > but I know identity is a pretty rare case.
> > P.
> > On 2/18/08, Martin Davis <mbdavis at refractions.net> wrote:
> > > There's some new code on the way in GEOS and PostGIS which will
> > improve
> > > the performance of this case.  Bu it won't be anywhere near as fast as
> > > your proposed check for an identical start point.
> > > The "identical start point" check is great for the particular case of
> > > comparing identical polygons.  But it does nothing for the general
> > > case.  The question is:  is the identical compare case common enough
> > > that it's worth adding in this check for all cases?
> > > Willy-Bas Loos wrote:
> > > > Hi,
> > > > I´ve noticed that intersect(a,b) is slow when i compare a (nice and
> > > > large) geometry with itself.
> > > > so the syntax is:
> > > > select 'yes' as foo
> > > > where a.gid=4
> > > > and b.gid=4
> > > > and intersects(a.the_geom, b.the_geom)
> > > > This particular polygon has about 10 000 points, and the query runs
> > > > for 4 whole seconds.
> > > > At the first point that is being compared, however, PostGIS should
> > > > notice that it has a "positive".
> > > > I´m only using postgis 1.0, so this migt have been changed allready.
> > > > Has it?
> > > > WBL
> > > > _______________________________________________
> > > > postgis-users mailing list
> > > > postgis-users at postgis.refractions.net
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > > Martin Davis
> > > Senior Technical Architect
> > > Refractions Research, Inc.
> > > (250) 383-3022
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080219/c94f7223/attachment.html>
