[postgis-users] Re: [postgis-devel] Proposal for supporting Extrude, Tessel
Martin Davis mbdavis at refractions.net
Thu Feb 28 15:26:05 PST 2008
I would respectfully disagree...  Not on the philosophical grounds of
styling vs data, but on the purely pratical ground that it would be a
pain to try and inject the geometry attributes into the generated XML
after the fact.
I can see why Google chose to embed the purely "geometric" styling
parameters within the Geometry XML, but it's quite a pain for several
reasons.  One is that this kills compatibility with GML (and thus
prevents or at least makes it a lot more complex to reuse code that
reads & writes GML).  I'm feeling this pain right now while working on
improving the JTS GML API.
guido.lemoine at jrc.it wrote:
> In effect, this issue is about styling of KML, and not so
> much about the real data itself. I wonder whether postgis
> should be concerned with that too much.
> askml() produces only partial KML fragments anyway, so you
> always have to make an effort, external to postgis, to
> produce valid KML for display in GE (e.g. using XSLT).
> This may as well include styling.
> I'm not suggesting this is not a good idea, but IMHO, it's
> not essential.
> GL
>> -- Original Message --
>> From: Dane Springmeyer <blake at hailmail.net>
>> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>> Date: Tue, 19 Feb 2008 09:45:14 -0800
>> Subject: [postgis-users]
>> 	Re: [postgis-devel] Proposal for supporting Extrude, Tesselate,
>> 	and Altitudemode options in PostGIS KML generator
>> Reply-To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>> As far as the KML proposal and syntax, I think both Paul and Martin's
>> suggestions are good improvements.
>>> What about providing a string parameter which can supply the various
>>> options in a human-readable format?
>>> E.g. "extrude=1 tesselate=0 altitudeMode=clampToGround"
>>> Easy to read, easy to parse, easy to extend...
>> If I had to choose between them I think the ease of reading of this
>> approach above is the nicest, if not most grass=like.
>> Thanks so much to Eduin for pulling this together.
>> Anyone have more thoughts?
>> Cheers,
>> Dane
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
