[postgis-users] function addgeometrycolumn does not exist
cummings peter at cummings.dk
Tue Jan 1 17:42:14 PST 2008
Hi There
I'm pulling my hair out with a problem, and I hope someone can help me...
I'm on a ubuntu gutsy server, with postgres 8.2 and postgis installed
through apt-get.
Now when working with the database, it now tells me that the functions do
not exist:
test=# select AddGeometryColumn('public','navaids','geom',32611,2);
ERROR: function addgeometrycolumn("unknown", "unknown", "unknown", integer,
integer) does not exist
LINE 1: select AddGeometryColumn('public','navaids','geom',32611,2);
HINT: No function matches the given name and argument types. You may need to
add explicit type casts.
However when I list my functions using \df this is a snippet of what i see:
public | addgeometrycolumn | text | character varying, character varying,
character varying, character varying, integer, character varying, integer
So the function should be in there, when I try other postgis functions like
pointfromtext, it works..
lwpostgis.sql and spatial_ref_sys.sql have been imported, and I'm also tried
creating a database using template_postgis.
Version info:
test=# select postgis_full_version();
 POSTGIS="1.2.1" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0, 22 Oct 2006"
USE_STATS
(1 row)
I hope someone can help me with this.
View this message in context: http://www.nabble.com/function-addgeometrycolumn-does-not-exist-tp14572464p14572464.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
