[postgis-users] Area calculation oh two polygon that they are overlapping
Paul Ramsey pramsey at refractions.net
Thu Jan 10 09:33:40 PST 2008
ST_Area(ST_Intersection(g1,g2)) ?
On Jan 10, 2008, at 8:23 AM, olivier.amram at free.fr wrote:
> Yes, but how do you calculate the area of the intersection ?
> Olivier.
> Selon Guido Lemoine <guido.lemoine at jrc.it>:
>> Your multipolygon is simply two rings of 3 by 3. Defining them
>> as multipolygon does do nothing for intersection, so the area is 18
>> (which is 9 + 9). You need to look up what intersection means.
>> For me, the intersection of the 2 polygons is the common area,
>> which is 4.
>> GL
>>> Hi,
>>> I'd like to compute the total area of polygon that intersects with
>>> another
>>> polygon
>>> Polygon(0 0,0 3,3 3,3 0,0 0)
>>> Polygon(1 1,4 1,4 4,1 4,1 1)
>>> The total area is 14 but I don't find a solution to compute this
>>> value.
>>> e.g. SELECT Area(GeomFromText('MultiPolygon( ((0 0,0 3,3 3,3 0,0
>>> 0)),((1
>> 1,1 4,4
>>> 4,4 1,1 1)))')) --> 18
>>> Have you any idea ?
>>> Thank,
>>> Olivier.
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Guido Lemoine
>> Joint Research Centre, European Commission
>> Institute for the Protection and Security of the Citizen (IPSC)
>> Support to External Security
>> Via E. Fermi, 2749 TP 267 Ispra 21027 (VA), Italy
>> Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
>> WWW: http://ses.jrc.it
>> Disclaimer:
>> Views expressed are those of the individual and do not represent
>> the views of the European Commission
