[geos-devel] Re: [postgis-users] ST_Contains doesn't work?
Paul Ramsey pramsey at refractions.net
Thu Jan 17 20:02:13 PST 2008
I think this must be arising in the "I'm a box so I can short-circuit
full computation" code. The error displays with different combinations
of square and non-square arguments.
On Jan 17, 2008, at 7:55 PM, Paul Ramsey wrote:
> I just confirmed this behavior. true/true on geos 2.2 true/false on
> geos 3.0.
> Please file this at http://trac.osgeo.org/geos, it's real, and it's
> not right.
> P
> On Jan 17, 2008, at 7:35 PM, KXK wrote:
>> SELECT
>> ST_Contains(
>> GeomFromText('POLYGON((0 0,0 10,10 10,10 0,0 0))', -1),
>> GeomFromText('POLYGON((5 5,5 6,6 6,6 5,5 5))', -1) );
>> returns TRUE
>> But,
>> SELECT
>> ST_Contains(
>> GeomFromText('POLYGON((0 0,0 11,11 10,10 0,0 0))', -1),
>> returns FALSE
>> I thought the above would also return TRUE.
>> Is this behavior of ST_Contains correct?
>> [VERSION INFORMATION]
>> OS: fc6
>> PostgreSQL: 8.2.4
>> PostGIS: 1.2
>> GEOS: 3.0.0
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
