[postgis-users] Maintain length and precision for numneric fields in pgsql2shp and shp2pgsql
Paul Ramsey pramsey at refractions.net
Wed Jan 23 08:59:38 PST 2008
On Jan 23, 2008, at 3:39 AM, Peter Hopfgartner wrote:
> we were looking at the tables generated by shp2pgsql. As it seems,
> numeric(m, 0) is mapped, if possible to integers, and numeric(m,n)
> is mapped to numeric.
Do you mean, mapped to float?
> We would like to optionally maintain the numeric length and
> precision for our data imports. Looking at shp2pgsql.c,  this should
> be rather simple. Basically, we could add an option, let's say '-K'
> for keep precision, and modify the code around line 550.
This is possible. You need to be aware of the *massive* performance
penalty that comes with using numeric instead of integer/float.  As
long as you are clear on that, it's certainly acceptable.
Since we have -i for "force to integer" how about -n for "use numeric
for all numbers"?
> A similar change could be done for pgsql2shp, modifying the SQL
> query, which gets the type information from PostgreSQL and changing
> the code generating the dbf header.
> If such a change is welcomed, we can try to have it done soon.
> Regards,
> Peter Hopfgartner and Sergio Segala
> R3 GIS
> http://www.r3-gis.com
> postgis-users mailing list
