[postgis-users] Spatial query Help: points not in set of polygons
Obe, Regina robe.dnd at cityofboston.gov
Thu Jan 24 03:41:03 PST 2008
SELECT a.*
FROM point a LEFT JOIN polygons b
	ON (a.the_geom && b.the_geom
    and ST_distance(a.the_geom, b.the_geom) = 0.0)
WHERE b.the_geom IS NULL
or
SELECT a.*
	ON ST_Within(a.the_geom, b.the_geom)
I think the second one should be more efficient, but I haven't done any
benchmarks.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Stephen Woodbridge
Sent: Wednesday, January 23, 2008 10:27 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Spatial query Help: points not in set of
polygons
Hi all,
I'm drawing a blank on setting up a query for this.
I have a tables points and a table of polygons. I need to find all the
points that are not in any of the polygons.
select a.*
   from points a, polygons b
  where a.the_geom && b.the_geom
    and distance(a.the_geom, b.the_geom) > 0.0;
The problem with this is that if a point is in polygon A it will have a
distance to polygon B, so this in no good.
I thought of doing something like:
select * from points
  where distance(the_geom, union((select the_geom from polygons))) >
0.0;
or
  where distance(the_geom, collect((select the_geom from polygons))) >
0.0;
So is there a better way to do this. Seems like there should be. If not
which of these would you suggest.
Thanks,
   -Steve
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
