[postgis-users] geometry column permission denied
David Epstein davideps at umich.edu
Sun Jan 27 07:53:31 PST 2008
Paul,
It has taken some time for me to get back to this problem. You were
indeed correct. Now that it is actually working I have some other
questions that I will post under another subject. Thank you again for
your help!
-david
Date: Wed, 09 Jan 2008 09:13:35 -0800
Subject: Re: [postgis-users] geometry column permission denied using
        shp2pgsql
Permission problems and encoding problems are quite separate, so let's
examine the first problem first. Your first error is the permission
problem. What happens when you log in as yourself with psql and try to
insert a column into geometry_columns? Hopefully it should fail, since
that's all the shp2pgsql-generated script is doing.
Run \d and see who owns that table. Probably it's owned by postgres
and you don't have rights to it. Log in as postgres and do some GRANTS
to provide yourself permissions and run from there.
The encoding issue is separate, and you seem to be on the right track
with the -W switch, assuming that ISO-8859-8  is in fact the original
encoding.
