[postgis-users] The lazy donut maker
Kevin Neufeld kneufeld at refractions.net
Tue Jan 29 08:27:56 PST 2008
Hi Gus,
There isn't a function to to that exactly, but you can accomplish it
easy enough by doing just what you said ... appending the startpoint to
the end of the linestring.
ie.
UPDATE my_lines SET geom = ST_AddPoint(geom, ST_StartPoint(geom));
SELECT isring(addpoint(geom, startpoint(geom)))
FROM (select 'LINESTRING(0 0, 0 1, 1 1, 1 0)'::geometry as geom) as foo
I suppose you could also run your lines through the snaptogrid function
to remove duplicate points ... just in case you added a startpoint to an
already closed ring.
Cheers,
Kevin
Gustavo Ces wrote:
> Thanks Kevin,
>    I´ll try it later, because it seems dump gives something different
> i expected, so some experimentation is required. By the way, I´m
> trying a different approach and i´ve got a question. After searching
> in postgis list and manual, i can´t find a postgis function to close
> an open linestring. So i supose  have to add the first point as the
> last one in my not very complex polygons. No problem. But my question
> is, is there any other way? I think this type of job is very usual
> (Arcgis, Cad software has functions to do it), so i´ts strange all
> postgis folks write a large sentence to solve this... Is there any
> Postgis function  or postgis trick?
> Maybe this mail is linked to another ones, talking about "reinventing
> the wheel"? :)
> Gus
> postgis-users mailing list
