[postgis-users] Problems while loading lwpostgis.sql... Please provide your inputs / help
Andy Dale andy.dale at gmail.com
Wed Jan 30 05:22:38 PST 2008
Have you added /usr/local/lib to /etc/ld.so.conf and then performed a
ldconfig ?
Cheers,
Andy
On 30/01/2008, ahmadbasha.shaik at wipro.com <ahmadbasha.shaik at wipro.com>
wrote:
>  Hi
> I am facing problems while loading lwpostgis.sql in PostGIS. Below is a
> detailed explanation.
> psql -d test -f /usr/share/lwpostgis.sql
> ERROR:  could not access file "$libdir/liblwgeom.so.1.2": No such file or
> directory
> ERROR:  current transaction is aborted, commands ignored until end of
> transaction block
> Hence , I tried creating a simple test.sql which has the create replace
> functions for histogram. I have detailed the environmnent that we are
> using, the statement of lwpostgis.sql we executed and the error
> encountered
> Environment:
> Operationg System : Red Hat Linux 3.4.5-2
> Database : PostgreSQL 8.2.6
> Extensions : geos-3.0.0, proj-4.6.0, postgis-1.2.1
> test.sql (three sql commands that I have taken from lwpostgis.sql to
> check)
> BEGIN;
> CREATE OR REPLACE FUNCTION histogram2d_in(cstring)
>         RETURNS histogram2d
>         AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_in'
>         LANGUAGE 'C' IMMUTABLE STRICT; -- WITH (isstrict);
> CREATE OR REPLACE FUNCTION histogram2d_out(histogram2d)
>         RETURNS cstring
>         AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_out'
> CREATE TYPE histogram2d (
>         alignment = double,
>         internallength = variable,
>         input = histogram2d_in,
>         output = histogram2d_out,
>         storage = main
> COMMIT;
> ERROR Encountered
> BEGIN
> psql:test.sql:6: NOTICE:  type "histogram2d" is not yet defined
> DETAIL:  Creating a shell type definition.
> psql:test.sql:6: ERROR:  could not access file "$libdir/liblwgeom.so.1.2":
> No such file or directory
> psql:test.sql:11: ERROR:  current transaction is aborted, commands ignored
> until end of transaction block
> psql:test.sql:19: ERROR:  current transaction is aborted, commands ignored
> ROLLBACK
> Varions Options we tried:
> a) Changed the permissions $libdir i.e. /usr/lib/pgsl to 777
> b) Hardcoded the path /usr/lib/pgsql in this test.sql
> c) We also tried hardcoding the path /usr/lib/pgsql instead of $libdir in
> lwpostgis.sql when we tried loading functions and types in lwpostgis.sql
> Can somebody please guide us or give directions what can be done.
> Regards
> Ahmad
> *P** Please do not print this email unless it is absolutely necessary.
> Spread environmental awareness.*
> The information contained in this electronic message and any attachments
> to this message are intended for the exclusive use of the addressee(s) and
> may contain proprietary, confidential or privileged information. If you are
> not the intended recipient, you should not disseminate, distribute or copy
> this e-mail. Please notify the sender immediately and destroy all copies of
> this message and any attachments.
> WARNING: Computer viruses can be transmitted via email. The recipient
> should check this email and any attachments for the presence of viruses. The
> company accepts no liability for any damage caused by any virus transmitted
> by this email.
> www.wipro.com
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080130/5ecf8f24/attachment.html>
