[postgis-users] MacPorts/PostGIS - Installation in different Schema
Kevin Neufeld kneufeld at refractions.net
Thu Jan 31 10:44:49 PST 2008
Hi Stefan,
As far as I know, following other PostgreSQL contrib modules, PostGIS
currently only installs in the public schema (unless someone has put
some work into this).  As I mentioned, this is the same for most other
contrib modules, like tsearch2, btree_gist, or cube.  So, if ever you
wanted to install other PostgreSQL extensions, their functions /
datatypes / tables would also install in public, getting mixed up with
tables/functions you've defined there.
The solution here is simple.  As a best practice, reserve the public
schema for contrib modules, storing user-defined tables / functions /
objects in user-defined schemas.  Following this best practice also
makes upgrading PostGIS significantly simpler since you can simply dump
and restore your user-defined schema (rather than hunting through the
public schema trying to determine which functions are yours, postgis's,
cube's, tsearch2's, etc.)
Cheers,
Kevin
Kevin Neufeld
Software Developer
Refractions Research Inc.
300-1207 Douglas St.
Victoria, B.C., V8W 2E7
Phone: (250) 383-3022
Email: kneufeld at refractions.net
Stefan Schwarzer wrote:
> Hi there,
> I would like to know if somebody could tell me how I can - by using
> the PostGIS MacPort - install the postgis functions not in the schema
> "public", but in another schema (to separate it from the tables which
> are being inserted into the public schema).
> Thanks for any hints,
> Stef
>  ____________________________________________________________________
>   Lean Back and Relax - Enjoy some Nature Photography
>   http://photoblog.la-famille-schwarzer.de
> <http://photoblog.la-famille-schwarzer.de/>
>   Appetite for Global Data? UNEP GEO Data Portal:
>   http://geodata.grid.unep.ch <http://geodata.grid.unep.ch/>
> postgis-users mailing list
