[postgis-users] makepolygon with geom info
Obe, Regina robe.dnd at cityofboston.gov
Tue Jul 1 05:53:24 PDT 2008
Try
Are each of your the_geom single point geometries?
If so I think you can do something of the form
SELECT Max(f.gid) as newgid, ST_MakePolygon(ST_MakeLine(f.the_geom)) As
newgeom, f.name
FROM (SELECT gid, the_geom FROM foll ORDER BY name, gid) As f
WHERE f.name = 'abc'
GROUP BY  f.name
Although the above assumes that your gid field controls the order of the
points along the line string and that your beginning and ending point
are the same.
If your beginning and ending are not the same - but your order is still
right, then you can do
SELECT Max(f.gid) as newgid, f.name,
ST_MakePolygon(ST_MakeLine(f.the_geom)) As newgeom
FROM (SELECT name, 0 as psort, gid as newsort, the_geom
		FROM foll
	UNION ALL
		SELECT fs.*
		FROM
		(SELECT DISTINCT ON(name) name, 1 As psort, gid ,
the_geom
			FROM foll
		ORDER BY name, gid) fs
	ORDER BY 1,2,3) As f
GROUP BY  f.name
If you leave the WHERE clause out, it will give you a Polygon record for
each unique abc.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
S.Reena
Sent: Tuesday, July 01, 2008 7:33 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] makepolygon with geom info
I have a table with foll fields( the_geom, name, latlon, ....)...i
wanted to
make a polygon by using those points whose name like 'abc' and put it in
the
map...
how to do dis?
View this message in context:
http://www.nabble.com/makepolygon-with-geom-info-tp18214128p18214128.htm
l
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
