[postgis-users] Re: Installing PostGIS on Suse
Ralf yukyuk at gmx.com
Tue Jul 1 07:44:03 PDT 2008
Thanks everybody for the heads up! Finally my installation worked out. I had problems cause I installed everything from the sources except proj.4 (used an rpm package). After installing proj.4 from the sources, and after adding the /usr/local/lib path to the LD_LIBRARY_PATH env., it seems as if it is running. So finally my installation is completely build from the sources. Mixing installation-methods like rpm and "from source" seems to end up in conflicts cause they use different install locations for the different methods!?!
Thanks again everybody. Will come up with further questions the next hours/days :-)
-- Ralf
