[postgis-users] Geometry appears empty
geoffi geoff.innes at ngis.com.au
Tue Jul 1 21:53:00 PDT 2008
Hi Tim,
OK to clarify...
 I have 694 records in my table, all have geometry based on the query:
    select count(*) from gen_poly
    where ST_IsValid(geom);
       count
          694
      (1 row)
When viewed in pgAdminIII only a handfull "appear" to have actual data in
the geom column (see original post). This is also the result when queried
using psql. The rest "appear" to be null.
FME proves that all 694 geometries exist and can display and interrogate
them.
Pushing the data out as a WMS via GeoServer only displays the handfull that
can be "seen" in psql and pgAdminIII.
So, we've established that all geometries are valid, but only some can be
seen using the Postgres tools or GeoServer. FME can see ALL the geometries!
Tim Bowden wrote:
> On Tue, 2008-07-01 at 20:28 -0700, geoffi wrote:
>> Hi Tim,
>> First of all I can confirm that the geometries are not null by:
>>    a) select count(*) from <my_table> where geom is null;
>>        This returns a count of 0.
>>    b) the FME Universal Viewer successfully displays all the geometries
>> successfully. Features can be graphically selected and their attributes
>> interrogated.
> Ok, so you're saying there is geometry data is in postgis for each
> record?  You seem to be negating this further down.
>> The link you gave seems to imply that pgAdminIII may not be the tool to
>> use
>> to verify geometry columns. It also mentions a possible limitation for
>> the
>> number of verticies hitting a limit of 1365. I will need to check my
>> geometries if this is the same in my case.
> This limitation is just PgAdminIII's ability to view the data.  It does
> not affect what's in the DB.  I'd be  surprised if there isn't a fix on
> the way for PgAdminIII as this has been around for a while now.
>> In the meantime, I've also used the psql command line interface to check
>> the
>> records with the same results as per the pgAdminIII. Can you recommend
>> another tool I can use to report the geometry data?
> Prefer psql over PgAdmin myself (can't seem to break the cli habit).
> There should be no issues with using psql.  Are you saying some records
> don't contain geometry data (as per original PgAdmin view) or you got no
> null geom records?  Little confused now.
>> As mentioned in the original post, my final step is to publish a WMS via
>> GeoServer. Only those geometries that "appear" to be populated come
>> through
>> in the WMS. While this may be a GeoServer issue, it is still reporting
>> the
>> same information that "appears" in PostGIS.
>> Any other thoughts?
> Check the validity of your geoms.
> select count(*) from <table> where not ST_IsValid(the_geom);
> (or whatever your geom column is called).
> Regards,
> Tim Bowden
>> Tim Bowden wrote:
>> > Geoff,
>> > This earlier thread may be of interest:
>> http://postgis.refractions.net/pipermail/postgis-users/2008-March/018814.html
>> > It deals with limitations of pgadmin and postgis.
>> > If the geometries really are null, are you also able to try loading the
>> > data with ogr2ogr to see if you get the same result?   Are you sure you
>> > don't have any invalid geometries?  I don't know how FME handles these.
>> > HTH,
>> > Tim Bowden
>> > On Tue, 2008-07-01 at 17:12 -0700, geoffi wrote:
>> >> I have translated some polygon data into a PostGIS table using FME.
>> The
>> >> translation was successful with no errors reported. All the records
>> >> appear
>> >> in the PostGIS table (using the pgAdminIII application) except for
>> about
>> >> 90%
>> >> of the geometries (see image below).
>> >> http://www.nabble.com/file/p18227858/table.jpg
>> >> However, using the FME Universal Viewer all records are displayed with
>> >> their
>> >> correct geometry as I would expect.
>> >> What is causing the Geometry column in the table to appear empty?
>> >> Is there a setting in PostGIS to force the data to be visible in the
>> >> pgAdminIII application?
>> >> Attempts to generate a WMS from this table using GeoServer only
>> displays
>> >> those records that appear to have geometry.
>> >> Performing a similar exercise using point geometries, there was no
>> >> problem.
>> > vim is a good example of an IDE done properly.  emacs is an example of
>> > an IDE done poorly.  Anything that involves little pictures is a
>> > mis-umderstanding of what an IDE should be.
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
View this message in context: http://www.nabble.com/Geometry-appears-empty-tp18227858p18230282.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
