[postgis-users] Is CIRCULARLINESTRING ready for use?
Thu Jul 3 10:48:00 PDT 2008
Bruce Rindahl wrote:
> I also have numerous parcels with circular arcs for testing but you must
> tell me what the syntax is.  The documentation gives CIRCULARSTRING(0 0,
> 1 1, 1 0) but does not tell you what the points 0 0 , 1 1  and 1 0
> mean.  Three point arc?  Start, end, center?  Let me know and I will
> send you lots of shapes.
Bruce,
Start, End and any other point on the arc that isn't the start or end.
Note necessarily the center.  In the case of a circle the start and
end are the same, but the intermediate point *is* required to be the
arc center (ie. the opposite side of the circle).
> Finally I have to question the support of circularstrings if we don't
> support ellipses.  The circle of Delaware is an ellipse in every
> projection except geodetic (?).  We can't correctly project a
> circularstring to anything and maintain the spatial relationship.  For
> example in SVG there is no circle command in paths - only ellipses.  A
> circular arc is defined as an ellipse with both radii the same.
://postgis.refractions.net/mailman/listinfo/postgis-users
I too am dubious about the use of a circular arc segment instead of
an elliptical arc segment.  However, in this regard PostGIS is just
tracking OGC and ISO standards, so take the argument to them.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
