[postgis-users] import large multipolygon
sub3 steve at subwest.com
Fri Jul 4 12:41:08 PDT 2008
I am having a problem.  I convert a shp file using shp2pgsql.  One of the
multipolgons is very large (line is about 277k characters long).  After I
import into postgresql, this geometry is empty.
No error from postgis.
No error from postgresql.
I am only making a guess that it is the line size, I am not sure.  Is there
a setting which would fix this?
Thanks for any help.
Attached is the .sql script.
http://www.nabble.com/file/p18285042/testtable.sql testtable.sql
View this message in context: http://www.nabble.com/import-large-multipolygon-tp18285042p18285042.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
