[postgis-users] questions about geometry_columns base table!
Obe, Regina robe.dnd at cityofboston.gov
Wed Jul 9 03:46:48 PDT 2008
1) Table _catalog menat to hold the database name, but in most cases
postgis just leaves that blank since there is a geometry_columns table
per database.  I'm not quite sure if the specs require that be filled in
though.  In theory it should since the standard ANSI SQL
information_schema tables require it filled in.
2) Well as you may have noticed - Postgis doesn't follow the MM Part 3
spec yet as for as these meta tables are concerned e.g. they don't start
with ST_ yet and geometry_columns is a physical table.  I haven't taken
that close a look at the specs to see if they really
require SRS_Name be the primary key.  Are you sure that is the case.
Most systems I know of based on my limited understanding key off of the
SRS_SRID.
Having the SRS_NAME be unique however doesn't seem like a bad idea since
it would prevent equivalent spatial reference systems from having 2
different identities.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
zhangmb
Sent: Wednesday, July 09, 2008 5:44 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] questions about geometry_columns base table!
Hello,I have some questions about SQL/MM part 3:spatial.
1. In the definition of st_geometry_columns base table, what is the
meaning of the TABLE_CATALOG and what it should store exactly? what is
the meaning of the unqualified schema name and the qualified identifier?
2. In the definition of st_spatial_reference_systems base table, why
using SRS_NAME as primary key as opposed to using SRS_SRID?
Thanks a lot!
--zhangmb
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080709/a6ba6d45/attachment.html>
