[postgis-users] Splitting/merging linework into equal interval linestrings
Dane Springmeyer blake at hailmail.net
Thu Jul 10 11:38:18 PDT 2008
Regina and Brent:
Wow. Thanks so much for the pointers.
I've now got a single query that is working excellently so far.
Without indexes it runs on the entire dataset in about 5 minutes when
splitting lines to ~ 150 m, which is just fine.
I was able to use the ST_Reverse function to make sure that any
fragments at the end of the linestrings would occur at the upstream
end, which I think handles my minimum requirement (for now).
Below is what just a slight reworking of Regina's second email example
looks like.
Thanks!
Dane
drop table if exists test2;
create table test2 (oid serial,strahler varchar, geometry geometry);
INSERT
INTO test2 (strahler, geometry)
SELECT strahler,
   -- take a substring if the length is greater than 152.4 meters
otherwise take the remainder
   ST_Line_Substring(geometry, 152.4*n/length,
   CASE
     WHEN 152.4*(n+1) < length THEN 152.4*(n+1)/length
     ELSE 1
   END) As geometry
FROM
   (SELECT strahler,
   -- reverse the vertex order so that the upstream end of each
linestring will be the remainder
   ST_LineMerge(ST_Reverse(ts.geometry)) AS geometry,
   ST_Length(ts.geometry) As length
   FROM sshiap_lines ts
   ) t
CROSS JOIN generate_series(0,10000) n
WHERE n*152.4/length < 1;
On Jul 9, 2008, at 10:21 PM, Paragon Corporation wrote:
> Dane,
> I recall doing something along 2 and 3 before and I did it in python
> (although I was interested in getting each measure at x distance
> along the
> line so I was collecting
> Points every x distance meters along the way rather than breaking up
> the
> lines.  So my translation of what I did to what you want may have a
> lot of
> logical errors)
> For 2 - I think your logic would look something like
> 2) SELECT gid, length*frac As dist,
> ST_Line_Substring(the_geom,startfrac,
> endfrac) As the_geom
> FROM (SELECT gid, 500*n/length As startfrac, CASE WHEN 500*(n+1) <
> length
> THEN 500*(n+1)/length ELSE 1 END As endfrac, length, the_geom
> 	FROM (SELECT ts.gid, ST_LineMerge(ts.the_geom) As the_geom,
> ST_Length(ts.the_geom) As length FROM line_segments ts
> 		) t CROSS JOIN generate_series(0,10000) n
> 	WHERE n*500/length < 1) As segments_500
> The above basically assumes your data is in some meter projection
> and you
> have no line segment that has got more than 10000 (500 ft segments)
> If you know for sure there is no way you have a line segment greater
> than
> 500*10000 then you can safely reduce that generate_series number and
> get
> better performance.
> This I did do in python by the way - and my logic is much more
> complicated
> than above but hopefully I cut out enough for you to get the basic
> idea
> 3)  For this I used python and the gdal and psycopg libraries.
> Basic logic
> looks something like Below
> open up a tile (my above query (maybe taking the centroid of each
> point I
> actually limited to only those linesegments that intersected the
> tile I was
> loading so I processed one tile at a time) - so my above query had
> an extra
> join with the tile extent
> Looks something like below where pt is an array of the centroid
> points of
> the above query
> 			dataset =
> osgeo.gdal.Open('%(atilefolder)s/%(atilefile)s'%
> {'atilefolder':atilefolder,'
> atilefile':atilefile}, GA_ReadOnly)
> 			geot = dataset.GetGeoTransform()
> 			#0 0 row col is at top left corner of the tif so we
> need min_x, max_y that corresponds to pos (0,0)
> 			min_x = geot[0]
> 			max_y = geot[3]
> 			res_x = abs(geot[1])
> 			res_y = abs(geot[5])
> 			print 'Origin of tile ', atilefile , '= (',min_x,
> ',',max_y,')'
> 			print 'Pixel Size = (',res_x, ',',res_y,')'
> 			print 'Size is
> ',dataset.RasterXSize,'x',dataset.RasterYSize, 'x',dataset.RasterCount
> 			for pt in r:
> 				#for each point figure out the row col
> position in the tiff
> 				gid = pt[0]
> 				x = pt[2]
> 				y = pt[3]
> 				#print max_y - y
> 				row = int(math.ceil((max_y - y)/res_y))
> 				col = int(math.ceil((x - min_x)/res_x))
> 				#If point falls in grid proceed to determine
> elevation from tiff
> 				#Some line segments may have measures that
> span multiple tiles so we need to skip the measurement points that
> don't
> fall in the tile
> 				if row > 0  and col > 0 and
> dataset.RasterYSize > row and dataset.RasterXSize > col:
> 					numpoints = numpoints + 1
> 					pt_dist = pt[1]
> 					#grab  1 pixel at row col position
> in tif and return the band1 - which is the elevation
> 					rd_scan = dataset.ReadRaster(col -
> 1, row - 1, 1, 1)
> 					rd_area = struct.unpack('f' * 1,
> rd_scan)
> 					elev = int(rd_area[0])
> 					#your update statement goes here
>   Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Dane
> Blakely Springmeyer
> Sent: Wednesday, July 09, 2008 11:25 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Splitting/merging linework into equal
> intervallinestrings
> PostGIS users,
> I have 1:24k hydrographic linework that I need process in several
> successive
> steps using a postgis workflow.
> I'm stuck at step 2 of this overall workflow:
> 1) separate all linestrings into distinct Strahler Order groups (done)
> 2) split all linework into linestrings of 500 ft (while avoiding any
> linestring fragments smaller than 500 ft)
> 3) perform an elevation lookup to raster data to calculate the
> gradient of
> each 500 ft segment and..
> 4) combine all adjacent linestrings which fall into similar gradient
> classes.
> For step 2 I'm investigating using ST_Segmentize() and/or
> ST_Line_substring(), but I'd really appreciate some help with how to
> best
> approach the problem.
> ST_Segmentize seems to only insert more nodes/points into already
> very high
> resolution linework (ie nodes already exist at intervals much more
> frequent
> than 500ft), thus extracting linestrings from the result of
> ST_Segmentize
> clearly isn't as simple as using MakeLine() between each segment.
> ST_Line_Substring works on percentages which is smart, but I have
> yet to
> wrap my mind around how to measure each individual line such that I
> can
> translate percentage distance along a linestring into equal distance
> intervals.
> Anyone have examples or guidance?
> Thanks,
> Dane
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080710/5612c100/attachment.html>
