[postgis-users] Convert MULTIPOINT to POLYGON
Obe, Regina robe.dnd at cityofboston.gov
Mon Jul 14 10:27:43 PDT 2008
Ralf,
Have you tried
 ST_MakePolygon(ST_LineFromMultiPoint(multipoint))
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ralf
Sent: Monday, July 14, 2008 12:29 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Convert MULTIPOINT to POLYGON
Hey! Is there a simple way to create a polygon out of a multipoint? I
have a table with points (nodes) and another table ways. Every single
way is defined through two or more nodes. The two tables are connected
through way_nodes (it's an import from openstreetmap.org using
osmosis!). I figured out how to get all ways that are closed:
SELECT ways.id FROM ways WHERE ST_IsClosed( (SELECT
ST_LineFromMultiPoint( Collect(n.geom) ) FROM nodes n LEFT JOIN
way_nodes wn ON n.id=wn.node_id WHERE ways.id=wn.way_id) )
Now I am trying to store these closed ways as a polygon into another,
new table. While doing that, I have to convert the MULTIPOINT that is
returned by the Collect()-function into a POLYGON:
INSERT INTO way_geometry SELECT ways.id,
  ( SELECT 'GeomFromText(\'' || replace( astext( Collect(nodes.geom) ),
'MULTIPOINT', 'POLYGON(') || ')\', 4326)' FROM nodes
  LEFT JOIN way_nodes ON nodes.id=way_nodes.node_id WHERE
way_nodes.way_id=ways.id
FROM ways
WHERE ST_IsClosed( (SELECT ST_LineFromMultiPoint( Collect(n.geom) ) FROM
nodes n LEFT JOIN way_nodes wn ON n.id=wn.node_id WHERE
AND ST_NumPoints( (SELECT ST_LineFromMultiPoint( Collect(n.geom) ) FROM
ways.id=wn.way_id) ) >= 3
This always responds the error "parse error - invalid geometry". When I
INSERT one of these lines by hand everything works fine. Is there
another function to convert a MULTIPOINT into a POLYGON, maybe without
using AsText()? Or does anyone have another idea to deal with this?
Thanks a lot, Ralf
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
