[postgis-users] Postgis to ESRI shape file encoding problem
Gabriel Messner gabmessner at gmail.com
Fri Jul 18 04:52:22 PDT 2008
yes, you´re right; -W option only works with loader shp2pgsql.
The second option may be to define in the pgsql.conf file the following
line:
client_encoding = sq-iso-8859-1 (i´not sure if Postgresql recognize the
character encoding Latin1 for albanian as sq-iso-8859-1, but try with it or
search the equivalent and write it in the pgsql.conf file). Afterwards,
execute the dumper (pgsql2shp).
2008/7/18 Ervin Ramonllari <ervin.ramonllari at hotmail.com>:
> I tried that,
> it gives back an error. It doesn't recognize -W as an option or command.
> Date: Fri, 18 Jul 2008 13:24:28 +0200
> From: gabmessner at gmail.com
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] Postgis to ESRI shape file encoding problem
> Try pgsql2shp option:
> -W sq-iso-8859-1
> In Albanian, there are 4 special characters.
> Date: Fri, 18 Jul 2008 12:33:55 +0200
> In wich language are data?
>   Hello everybody,
> I'm trying to export some data from a Postgresql database encoded in UTF-8
> into some ESRI shape files.
> I'm using PostGIS Dumper (pgsql2shp).
> the export is done correctly, but some special characters could not be
> exported properly. I guess it's a problem of encoding but I can't figure out
> how to deal with it.
> I googled around but couldn't find something useful.
> Any help for solving my problem would be highly appreciated,
> thanks in advance,
> Ervin.
> Explore the seven wonders of the world Learn more!<http://search.msn.com/results.aspx?q=7+wonders+world&mkt=en-US&form=QBRE>
> postgis-users mailing list
> Connect to the next generation of MSN Messenger  Get it now!
> <http://imagine-msn.com/messenger/launch80/default.aspx?locale=en-us&source=wlmailtagline>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080718/65420d72/attachment.html>
