[postgis-users] Postgis to ESRI shape file encoding problem
Steffen Macke sdteffen at gmail.com
Sat Jul 19 05:37:37 PDT 2008
You can also try to set the environment variable PGCLIENTENCODING to the
encoding value you need (e.g. LATIN2).
Steffen
>> I'm trying to export some data from a Postgresql database encoded in UTF-8
>> into some ESRI shape files.
>> I'm using PostGIS Dumper (pgsql2shp).
