[postgis-users] match line with road segment
searchelite searchelite at gmail.com
Sun Jul 20 22:53:33 PDT 2008
Stephen Woodbridge wrote:
>>> You can buffer the line and see which segments fall inside the buffer.
>>> select * from roads
>>>   where ST_Contains(the_geom, ST_makeline(gps_points));
> Sorry, this should have been:
> select * from roads
>    where ST_Contains(the_geom, Buffer(ST_makeline(gps_points)), "value");
> where "value" is the radius of the sausage that you are going to make
> the line into. This has to be in the units of you data set, which is
> likely degrees. 69 mile ~= 1 degree, 69*5280 ft ~= 1 degree so 50 ft ~=
> 50/(69*5280) = 0.00013724 so try that for starters and adjust it as
> required to get good results.
> -Steve
thank you steve for your reply, i guess the buffer should be ST_buffer
right? but unfortunately it's not working...it said that aggregates not
allowed in WHERE clause
thank you
View this message in context: http://www.nabble.com/match-line-with-road-segment-tp18479996p18562572.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
