[postgis-users] Need Help with Postgis
Paragon Corporation lr at pcorp.us
Wed Jul 23 20:16:28 PDT 2008
Jorge,
If you don't have the table registered in the geometry_columns table then
that would be the problem like the error says.
Alternatively you don't need to have it in geometry_columns if you use this
syntax
DATA "the_geom FROM pai_vec_250 USING UNIQUE gid USING SRID=4326"
Where gid has to be a field in your table that uniquely identifies each
record.  I think Mapserver may put on the additional restriction that the
field needs to be an integer,
but I've never tried it with a non-integer unique identifier so I could very
well be wrong.
Hope that helps,
Regina
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
jeviloria at cantv.net
Sent: Wednesday, July 23, 2008 8:34 PM
To: Postgis-users at postgis.refractions.net
Subject: [postgis-users] Need Help with Postgis
Hello friends,
I try to run a MSW as follows:
http://www.sigtruj.org.ve/cgi-sys/mapserv?map=/home/sigtrujo/www
/map/prueba1.map&layers=mun_truj&mode=MAP
map file, is as follows:
MAP
  NAME
mun_t
  SIZE 400 400
  UNITS dd
  INTERLACE ON
  EXTENT -74.65
0.64 -56.89 12.19
  PROJECTION
    'init=EPSG:4189'
  END
FONTSET '../fonts/fonts.txt'
  SYMBOLSET '../simbolo/simbolo.txt'
Background color for the map canvas -- change as desired
  IMAGECOLOR
192 192 192
  IMAGEQUALITY 95
  STATUS on
	WEB
		TEMPLATE
"../plantilla.html"
		IMAGEPATH
"/home/sigtrujo/www/tmp/ms_tmp/"
		IMAGEURL "/tmp/ms_tmp/"
		#EMPTY
"http://www.sigtruj.org.ve/plantilla.html"
		LOG
"../mapservEdenWfsIow.log"
		METADATA
			"wms_title" 	     "WMS
Demo Server" ##REQUIRED - generates warning in xml output if
missing
			"wms_onlineresourse"
"http://localhost/cgi-bin/mapserver.exe"
			"wms_srs"
"init=epsg:24719"
		END
	END #end web
LAYER
    NAME
"mun"
    TYPE POLYGON
    CONNECTIONTYPE postgis
    CONNECTION
"host=localhost port=5432 user=sigtrujo_test password=andrea08
dbname=sigtrujo_sigtruj"
    DATA "the_geom FROM pai_vec_250"
METADATA
      "wms_title" "pai_vec_250"
    END
    STATUS
DEFAULT
    TRANSPARENCY 45
    PROJECTION
"init=EPSG:4189"
    END
    LABELITEM "nombre"
    CLASS
NAME "pai_vec_250"
       STYLE
         SYMBOL 0
OUTLINECOLOR 110 110 110
         COLOR 127 143 184
       END
LABEL
      SIZE MEDIUM
      COLOR 64 64 64
      OUTLINECOLOR
212 212 212
      POSITION CC
      PARTIALS FALSE
      FORCE
TRUE
      MINDISTANCE 0
      ANGLE 0
      BUFFER 4
ENCODING SJIS
     END
    END
  END
IMAGETYPE
PNG
OUTPUTFORMAT
   NAME PNG
   DRIVER "GD/PNG"
   MIMETYPE
"image/png"
   IMAGEMODE PC256
   EXTENSION "png"
   TRANSPARENT
ON
 END
END
This produces the following error.
msDrawMap(): Image handling error. Failed to draw layer named 'mun'.
prepare_database(): Query error. Error declaring cursor: ERROR: find_srid()
- couldnt find the corresponding SRID - is the geometry registered in the
GEOMETRY_COLUMNS table? Is there an uppercase/lowercase missmatch? With
query string: DECLARE mycursor BINARY CURSOR FOR SELECT
"nombre"::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::tex
t from pai_vec_250 WHERE the_geom && setSRID('BOX3D(-74.65 -2.465,-56.89
15.295)'::BOX3D, find_srid('','pai_vec_250','the_geom') )
I can help solve this problem?.
thanks
Jorge
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080723/9deaf037/attachment.html>
