[postgis-users] ESRI Geodatabases, relationship classes and PostGIS
Paragon Corporation lr at pcorp.us
Thu Jul 24 19:05:25 PDT 2008
Juan,
Can't say I'm even a mildly competent user of ArcGIS products, but hopefully
the little I know about the topic will be of help to you.
For GeoDatabase -> PostGIS -  OGR2OGR  has worked well for me, its free, and
also can deal with other formats as well.
We have some of the more commonly used cases we use documented on our site.
We recently added a Personal Geodatabase example which is further to the end
of the document
http://www.bostongis.com/PrinterFriendly.aspx?content_name=ogr_cheatsheet
For editing data in ArcMap
ArcGIS 9.3 has built in support, but I think you may need to purchase the
PostgreSQL SDE license to use it.  Check out Bill Dollins -
http://geobabble.wordpress.com  he has a number of articles on using both
builtin support and using ZigGIS
Paolo Corti -
http://www.paolocorti.net/2008/06/06/spatial-database-for-postgres-and-arcgi
s-users-how-to-choose/
Dave Bowman for some more examples of using ArcGIS 9.3 with PostGIS  -
http://blog.davebouwman.net/2008/05/12/PostGISRound2ReadingTheManual.aspx
If you are using ArcGIS 9.2 and below or you just need desktop editing
support (and are using ArcGIS 9.3) and don't want to pay for an SDE license,
check out ZigGIS plugin for ArcDesktop - http://www.obtusesoft.com/pr.html
Hope that helps,
Regina
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Juan
Declet
Sent: Thursday, July 24, 2008 4:59 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] ESRI Geodatabases, relationship classes and PostGIS
Hi, all. I am evaluating PostGIS to determine if it can suit our needs.
What I currently have is a personal geodatabase (.MDB) file, created in
ArcCatalog.
This geodatabase has a number of relationship classes created in ArcCatalog
that are
used in ArcMap to facilitate editing and addition of new features.
What I am looking for is a spatial data server where I can publish this
geodatabase and make it available for ArcMap users to connect to this data
source and edit the dataset. In other words, I need an Open Source
equivalent to ArcGIS Server or Arc Spatial Data Server (ArcSDE).
The questions are:
1. Will PostGIS recognize relationship classes created in ArcCatalog, being
that these are not exactly like those created in Access or in an Access-like
environment (i.e., relationship classes don't show up in the Relationships
window in MS Access)?
2. Can a client such as ArcMap connect to a PostGIS data source?
I appreciate the input of seasoned PostGIS users in this matter.
Regards,
Juan Declet
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080724/aedc46bc/attachment.html>
