[postgis-users] optimal textbased geometry format
Obe, Regina robe.dnd at cityofboston.gov
Thu Jul 31 04:09:20 PDT 2008
Actually now I realize the PostGIS binary notation is HexEWKB
SELECT ST_AsHEXEWKB(ST_GeomFromText('POLYGON((0 0,0 1,1 1,1 0,0
0))',4326))
SELECT ST_GeomFromText('POLYGON((0 0,0 1,1 1,1 0,0 0))',4326)::text
Gives same answer
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Willy-Bas Loos
Sent: Tuesday, July 29, 2008 1:12 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] optimal textbased geometry format
funny, the EWKB is exactly half the size of the "PostGIS binary
notation", in all cases i tested.
there is a small performance impact, which fluctuates somewhat. The
internal format was a factor 1.01 to 1.07 faster (94 to 99% of the time
needed).
cheers,
WBL
On Tue, Jul 29, 2008 at 6:48 PM, Willy-Bas Loos <willybas at gmail.com>
wrote:
	thanks.
	yes it helps :)
	On Tue, Jul 29, 2008 at 4:46 PM, Obe, Regina
<robe.dnd at cityofboston.gov> wrote:
		Haven't done any benchmarks, but I know the following
		the ::text display you get is basically the string
representation of the native binary format that PostGIS actually stores
the geometries.
		It is not WKB nor WKT.  Its a PostGIS proprietary format
if you will.  I would guess casting from that format is the most
efficient since in theory there is very little processing that
PostgreSQL needs to do to reconstitute from that format.
		Keep in mind EWKT and WKT also may result in floating
point errors since they will round the decimals so be careful using
those.
		So your best formats to maintain precision (and not have
lossiness) are EWKB and the ::text representation (which I shall dubb
the native PostGIS binary notation (which I guess we can call
light-weight something or other)).
		Hope that helps,
		Regina
Willy-Bas Loos
		Sent: Tuesday, July 29, 2008 8:43 AM
		To: postgis-users at postgis.refractions.net
		Subject: [postgis-users] optimal textbased geometry
format
		Sometimes i build queries inside plpgsql scripts, that i
then run using EXECUTE.
		Is there a preferred way to include geometries in those?
		I use postgis 1.1 (for now). Are there are any changes
in later versions that influence this aspect of PostGIS?
		The SRID is a factor for me, so asText(the_geom) is no
option.
		I eiter use asEWKT(the_geom), or just the_geom::text .
		Just casting the geometry directly into text results in
a very long text value (what is the name of this format?). The length of
the string might be a network transfer drawback.
		asEWKT results in human readable format, possibly
shorter, but it might require more processing power (back and forth!).
		I've tested both difference in length and performance,
all on a limited dataset.
		LENGTH:
		The difference in length varies greatly. I use SRID
28992, which is a national grid that has coordinates in meters, so it is
possible to have coordinates with 0 decimal places (1 meter precision).
Simple geometries seem to benefit most from the WKT format. The EWKT is
40% of the number of characters for some cases (square polygons from
coordinates without decimals). Most polygons score 50-60% of length, but
in some cases the WKT representation is up to 10% longer than the direct
cast (geom::text).
		code:
		  --select length(the_geom::text),
length(asewkt(the_geom)),
round(((length(asewkt(the_geom))::float)/(length(the_geom::text))::float
)*100) as perc
		  select
avg(((length(asewkt(the_geom))::float)/(length(the_geom::text))::float)*
100) as perc
		  from atable
		  order by perc
		PERFORMANCE:
		I've tested these "warm" (not the first run), and
averaged the scores from 3 measurements each. The fluctuations were
minimal.
		The diference in performance is small for converting
from geometries to a text representation. Casting directly is a factor
1.1 faster (90% of the time needed)
		The other way around is a diferent story. Converting a
directly casted geometry back to a geometry is a factor 6 faster than a
EWKT string (16% of the time needed)!
		I hope my method (code below) is adequate?
		code:
		  select area(the_geom::text::geometry)
		  --select area(asewkt(the_geom)::geometry)
		  from atable
		Regarding my tests, i would say that the format that
results from a direct cast is the better string representation for
intra-application communication. Are there any drawbacks?
		Of course my test was limited to a small dataset on a
windows pc (mem 2GB, athlon 64 3200+) with postgis 1.1. Does anyone else
have different results/ideas about this?
		Cheers,
		WBL
		The substance of this message, including any
attachments, may be confidential, legally privileged and/or exempt from
disclosure pursuant to Massachusetts law. It is intended solely for the
addressee. If you received this in error, please contact the sender and
delete the material from any computer.
		Help make the earth a greener place. If at all possible
resist printing this email and join us in saving paper.
		postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080731/690d6da4/attachment.html>
