[postgis-users] How to tell if 2 geometries are spatially equal
Andy Anderson aanderson at amherst.edu
Mon Jun 2 13:04:47 PDT 2008
I wouldn't call this example "topologically" equal; one has two
vertices and the other has three, and that's the only characteristic
that's relevant in topology (not even their positions :-)
"Coincident" is probably a better term, though "spatially equal" is
probably just as good, and contrasts well with the term "geometrically
equal" that the manual uses to describe the ~= operator.
-- Andy
On May 30, 2008, at 7:54 PM, Martin Davis wrote:
> Will ST_equals do what you want?  It reports whether two geometries
> are topologically equal.
> (So for example, ST_equals('LINESTRING(0 0, 10 10)','LINESTRING(0 0,
> 5 5, 10 10)') is true)
> Obe, Regina wrote:
>> I recall this having come up before.  I always thought that ~= would
>> tell me if 2 geometries are spatially equal but it doesn't seem to.
>> The only way I can figure to determine spatial equality is if
>> ST_Within(A,B)  And  ST_Within(B,A)  (or ST_Difference(A,B) AND
>> ST_Difference(B,A) both return an empty geometry collection)
>> --So case in point
>> SELECT geom1 ~= geom2 as what, ST_Within(geom1, geom2) AND
>> ST_Within(geom2, geom1) As spatial_equal,
>> 	ST_AsText(ST_Difference(geom1, geom2)) as diffgeom12,
>> ST_AsText(ST_Difference(geom2, geom1)) as diffgeom21 FROM (SELECT
>> 'LINESTRING(1 1, 1 2, 1 3)'::geometry As geom1, 	'LINESTRING(1 1, 1
>> 3)'::geometry As geom2) As foo
>> Results:
>> what | spatial_equal |        diffgeom12        |        diffgeom21
>> f    | t             | GEOMETRYCOLLECTION EMPTY | GEOMETRYCOLLECTION
>> EMPTY
>> Is there a function / operator that does that (also what does geom1 =
>> geom2 compare - is it just bounding boxes or is that the spatially
>> equal
>> operator I am looking for?)
>> Thanks,
>> Regina
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
