[postgis-users] pgsql2shp syntax - sentence construction
SenTnel elvin.pimentel at gmail.com
Mon Jun 2 16:41:49 PDT 2008
Hi! Im working with postgres and geoserver but im just not good at sql
statements, none the less in construction sentences in postgres, and I would
like to create a shapefile from a table in postgres and don't want to make a
costly mistake, so if you help me achieve this using pgsql2shp:
database name: mydatabase
schema: myschema
table: mytable
shapefile to be created: updatedshp
database user: postgres
password: any
can you help me with the syntax to achieve the shapefile containing all of
the data (and geom) in such table?
Thanks !
View this message in context: http://www.nabble.com/pgsql2shp-syntax---sentence-construction-tp17613265p17613265.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
