[postgis-users] Projection for Calculating Area
Robert Coup robert.coup at onetrackmind.co.nz
Tue Mar 4 00:59:56 PST 2008
On 22/02/2008, Dylan Beaudette <dylan.beaudette at gmail.com> wrote:
> If you have really big shapes that are spanning multiple UTM zones, then
> setting up some kind of pre-processing logic which determines 1 of several
> possible albers equal area conic projections might work. For example, if
> the
> coordinates are near the continental US, use one set of standard parallels
> central lon/lat to setup the projection. Adjust these parameters
> accordingly
> for different (continents?) regions of the world. You should be able to
> either find some existing EPSG codes which are close enough, or just make
> up
> your own, and define your projections in PROJ format. Then add them to the
> spatial_ref_sys table.
If your results don't need to be super-accurate, you could make the
simplifying assumption that the earth is spherical and calculate the area
accordingly - via something like http://tinyurl.com/2uhedb
Depends on what you're using it for.
Rob :)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080304/5d32c4ca/attachment.html>
