[postgis-users] Topological Exceptions
Obe, Regina robe.dnd at cityofboston.gov
Wed Mar 12 13:10:35 PDT 2008
Yes an ERROR() geometry even better. I suppose that is not part of the
OGC specs.
I was thinking that if it did at least return an empty collection - then
I could inspect the ones that returned an empty collection for issues or
simply throw them out with a filter if I didn't want to be bothered with
them, but an ERROR() geometry would be better to differentiate from
truly empty collections.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, March 12, 2008 1:18 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Topological Exceptions
Hard. An "ERROR()" geometry type is almost called for, so that you can
run the whole set and actual inspect post-facto which ones failed.
The most annoying part of the current behavior for me is the
difficulty tracking down the problematic pair of geometries.  I think
you're right, the current fail-and-stop behavior causes more problems
than it solves.
On 3/11/08, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> I've been doing a lot of work using ST_Intersection, ST_Difference,
ST_Union
> etc to cut out slices of geometries I don't want and slicing up
geometries
> into smaller pieces, reunioning etc.
> I've been running into a lot of Topological Exceptions of the form
directed
> Edge this and non-noded that.  For the most part I've been able to
overcome
> these by slicing things smaller or skipping over problem regions (e.g.
areas
> where the difference is a line or point or something of that sort).
> I think a lot of people have run into the same issues and have gotten
> frustrated and there doesn't seem to be a simple solution suggested to
> overcome these.
> Is there any way we can change (add overloaded functions or some
setting
> parameter) - that take additional parameters to simply ignore these
errors
> that says return empty collection or NULL when a GEOS error is thrown.
That
> way I can simply ignore these and throw them out of my equation and
move on.
> Just a thought.  I'm sure my suggestion is rather simple-minded and
I'm sure
> I'm missing some reason of why this is not feasible.  An explanation
of why
> my suggestion is stupid at anyrate would be nice.
> Thanks,
> Regina
> ________________________________
>  The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
pursuant to
> Massachusetts law. It is intended solely for the addressee. If you
received
> this in error, please contact the sender and delete the material from
any
> computer.
>  Help make the earth a greener place. If at all possible resist
printing
> this email and join us in saving paper.
>  postgis-users mailing list
>  postgis-users at postgis.refractions.net
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
