[postgis-users] NEED Win 64bit OleDb or ODBC Driver
Sufficool, Stanley ssufficool at rov.sbcounty.gov
Fri Mar 14 10:07:07 PDT 2008
This is with SQL 2005? I don't have the OLEDB --> ODBC option as far as
I can tell. I have tried SQLOLEDB and MSDAOSP and both fail with:
SELECT * FROM
OPENROWSET('SQLOLEDB',
'Driver={PostgreSQL
AMD64A};Server=server;Port=5432;Database=gis;Uid=user;Pwd=pass;',
'SELECT * FROM PRECINCT LIMIT 100')
OLE DB provider "SQLNCLI" for linked server "(null)" returned message
"Login timeout expired".
"An error has occurred while establishing a connection to the server.
Named Pipes Provider: Could not open a connection to SQL Server [2].
"Invalid connection string attribute".
I think the simple fact here is that SQL 2005 has removed support for
ODBC linked servers.
I'm not sure if I can get PgOleDb to port to AMD64 with my version of
VC++ 2008 Express since the driver uses ATL.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Bruce Rindahl
> Sent: Friday, March 14, 2008 9:05 AM
> To: 'PostGIS Users Discussion'
> Subject: RE: [postgis-users] NEED Win 64bit OleDb or ODBC Driver
> Use the ODBC driver to configure a connection to PostgreSQL.
> Then use the Microsoft OLEDB - ODBC driver to connect to the
> PostgreSQL database.  I have done this using the 32 bit
> drivers.  I don't know about 64 bit. Bruce
> Behalf Of Sufficool, Stanley
> Sent: Friday, March 14, 2008 9:56 AM
> To: PostGIS Users Discussion
> ODBC passes connectivity test at the manager level, however
> you can't use an ODBC driver (only OleDb) to link SQL 2005 to
> PostgreSQL servers :( .
> I don't suppose anyone has made inroads into porting the
> OleDb driver...
> > Sent: Friday, March 14, 2008 8:06 AM
> > I am running PostgreSQL on 64bit Linux. I Just need to link
> > the MS SQL 2005 Server to the UNIX PostgreSQL server. Being
> > that MSSQL 2005 is running 64bit, I need a 64 bit ODBC/OLEDB
> > driver for the windows side.
> > I checked out the ODBCNG source and attempted to build x64,
> > but it is failing on a few undefined consts
> > (PACKAGE_NAME/PACKAGE_VERSION/ODBCNG_FILE_NAME).
> > I'll try the beta x64 ODBC and see what flies.
> > Thanks
> > > Behalf Of Mark Cave-Ayland
> > > Sent: Friday, March 14, 2008 2:32 AM
> > > Subject: Re: [postgis-users] NEED Win 64bit OleDb or ODBC Driver
> > > On Friday 14 March 2008 00:02:48 Sufficool, Stanley wrote:
> > > > I am attempting to use linked servers (MSSQL / PG) on a 64bit
> > > > platform. I have been searching for a 64bit driver
> > > installer, but have
> > > > yet to find one.
> > > > Anyone have luck with this or do I need to roll my own?
> > > Hmmm given that there is no 64-bit version of PostgreSQL for
> > > Windows, I would be very surprised  if there was a 64-bit ODBC
> > > driver. You may find this
> > > following link useful:
> > > http://people.planetpostgresql.org/mha/index.php?/archives/162
> > -PostgreSQL-vs-64-bit-windows.html,
> > although I'm sure Magnus has mentioned that before that the
> > main problem is
> > to do with differing pointer sizes under Win64 compared to Unix :(
> > ATB,
> > Mark.
> > Mark Cave-Ayland
> > Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> > T: +44 870 608 0063 _______________________________________________
> > postgis-users mailing list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
