[postgis-users] st_union says geometries have different srids
mchapman at texelinc.com mchapman at texelinc.com
Sun Mar 16 21:43:58 PDT 2008
I'm not sure if this is related but I was using the same version of geos today but from c++ directly and I was also getting an error when trying to use geos union in a loop where I continually union the previous resulting union geometry to the next in the table.  It would always throw an error when parsing a multipolygon wkb saying that one of the linear rings was not closed (which it isn't).  When I just union two geoms then all unions work correctly.  The ring it complains about is a ring created from a previous union operation and it looks like the geos coordinate sequencer doesn't parse the ring correctly or the ring is failing on creation.  I validated my wkb binary and all rings in my table geometries are closed.
I think this is a possible geos problem.  I will debug further tomorrow and let you know if I find the error in the geos code and send you the fix if I find one.
Best regards,
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Mon, 17 Mar 2008 17:14:31
To:postgis-users at postgis.refractions.net
Subject: [postgis-users] st_union says geometries have different srids
Hello list,
I seem to be having trouble with st_union as an aggregate function.
Sorry if this is a known issue, but a quick search didn't turn anything
up similar.  Below is an example where I have two polygons next to each
test=# create table test (gid serial primary key);
test=# select
test=# insert into test (test_geom) values ('srid=4326;MULTIPOLYGON(((1
1,1 2,2 2,2 1,1 1)))');
test=# insert into test (test_geom) values ('srid=4326;MULTIPOLYGON(((2
1,3 1,3 2,2 2,2 1)))');
The following will fail no matter what shapes/srid I'm using:
test=# select st_union(test_geom) from test;
ERROR:  Operation on mixed SRID geometries
But this works fine:
test=# select st_memunion(test_geom) from test;
Is there something in particular that I'm doing wrong?  This only seems
to be an issue with st_union as an aggregate, if I use
st_union(geometry,geometry), the result looks fine.  This is on a
Fedora-7 (x86_64) machine with PostgreSQL 8.3, PostGIS 1.3.2,
Proj-4.5.0, GEOS-3.0.0 - I have a similar setup on another machine
running F8-x86_64 (except for Proj-4.6.0), and the failure is worse (the
postgresql server segfaults with 'signal 11').  Would this be a bug, or
have I committed some kind of user error?  Is there anything I should
try to figure out where the source of my problem is?
Thanks in advance for any suggestions.
postgis-users mailing list
