[postgis-users] Server closed the connection when use function "makeline_garray"
amnuay ch ch.amnuay at gmail.com
Mon Mar 17 08:13:11 PDT 2008
*What steps will reproduce the problem?*
1.when I user function "makeline_garray"
2.Server return SQL error:
*What is the expected output? What do you see instead?*
SQL error:
server closed the connection unexpectedly
       This probably means the server terminated abnormally
       before or while processing the request.
And:
log kernal(/var/log/message)
Mar 15 15:46:50 jupiter kernel: postmaster[30186]: segfault at
000000001d8eace8 rip 0000002aded43f86 rsp 0000007fbfffd610 error 4
*What version of the product are you using? On what operating system?*
PostgreSQL version: 8.3.0
Operating system:   Redhat RHEL4
PostGIS :1.3.2
GEOS: 3.0
Amnuay Chim-In
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080317/b4932cca/attachment.html>
