[postgis-users] Do I need to copy postGIS objects to my new schema?
Nicolas Ribot nicky666 at gmail.com
Tue Mar 25 08:21:50 PDT 2008
>  You will be able to use them on the bali.* tables by either fully
>  qualifying the tables' name in your queries or by adding your newly
>  created schema to the search path (no need to qualify tables names
>  with the schema in this case)
a query using qualified names could look like:
select st_isvalid(t.the_geom) from bali.island as t;
