[postgis-users] SQL Code to update a geometry column cell by oid?
Kevin Neufeld kneufeld at refractions.net
Tue Mar 25 08:30:31 PDT 2008
It looks like you are using the single quote to denote your string
literal being passed into conn.exec().  I suspect you'll need to escape
the quote wrapping your POINT string.
I don't know Ruby's syntax for quote escaping, but you could try:
conn.exec(
'UPDATE geograwdata SET LatLon = GeometryFromText(\'POINT('
+ result.coordinates[0].to_s + ' '
+ result.coordinates[1].to_s +
')\', 4326) WHERE oid = (a+17178);')
Also, the others are right. The use of an oid column has been
deprecated.  You should put a primary key or unique index on a serial
column on your table instead.
Further, I would recommend against using GeometryFromText since using a
textual representation will introduce coordinate drifting and precision
loss.
Use MakePoint instead and you won't have to do any string escaping. Perhaps:
conn.exec(
'UPDATE geograwdata SET LatLon = SetSRID(MakePoint('
+ result.coordinates[0].to_s + ', '
'), 4326) WHERE oid = (a+17178);')
Ideally, you would do this using something like Java's PreparedStatement
and simply set the fields to their actual double value.
Cheers,
Kevin
gameguy56 wrote:
> Alright, well, it's still not quite working.
>     conn.exec('UPDATE geograwdata SET LatLon =
> GeometryFromText('POINT(result.coordinates[0].to_s+'
> '+result.coordinates[1].to_s)',4326) WHERE oid = (a+17178);')
