[postgis-users] How do I span the international date line?
Brent Wood pcreso at pcreso.com
Sat Mar 29 13:08:07 PDT 2008
--- Paul Tomblin <ptomblin at xcski.com> wrote:
> Is there a way to make a rectangle that goes from, say, 45N 179W to 45S 179E
> without going through 0?  Is there a way to make one that goes from the same
> coordinates that *does* go through 0?
Hi Paul,
Nothing straightforward.
You can use longitudes between 0-360 instead of +-180, (so 170W=190) this
migrates the problem 180 degrees, but doesn't cure it, and you really need to
migrate all your data to one or the other.
I even have maps (tables) with data from -180 to 360, with the western
hemisphere replicated each side of the eastern. Not an elegant approach, but it
did resolve one web mapping issue requiring a seamless lat/long world
coastline.
You can also store your data in projected coordinates instead of (or as well
as)
lat/long. In this case displaying your data in lat/long will typically draw
lines & polygons across the world, but they normally plot OK in the projection.
HTH,
  Brent Wood.
> Paul Tomblin <ptomblin at xcski.com> http://blog.xcski.com/
> Considering the number of wheels Microsoft has found reason to invent,
> one never ceases to be baffled by the minuscule number whose shape even
> vaguely resembles a circle.  -- [unknown]
> postgis-users mailing list
