[postgis-users] PostGIS install on postgres 8.3 running on 64bit OpenSuse10.3
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri May 2 01:34:30 PDT 2008
Calum Byrom wrote:
> Hi,
> Has anyone managed to get PostGIS working on Postgres 8.3 running on
> OpenSuse10.3 on 64bit hardware?
> I've gone through the install instructions described at:
> http://liangzou.blogspot.com/2008/02/setting-up-postgresql-with-postgis-on.html
> and everything works ok until I get to the point of running:
> psql -d dgvbr -f lwpostgis.sql
> - this then throws up the error:
> BEGIN
> psql:/home/cbyrom/postgis-1.3.3/lwpostgis.sql:44: NOTICE:  type
> "histogram2d" is not yet defined
> DETAIL:  Creating a shell type definition.
> psql:/home/cbyrom/postgis-1.3.3/lwpostgis.sql:44: ERROR:  incompatible
> library "/usr/lib64/postgresql/liblwgeom.so": versi
> on mismatch
> DETAIL:  Server is version 8.3, library is version 8.2.
> I've downloaded and installed the latest versions of the required software:
> postgresql-8.3.1
> proj-4.6.0
> geos-3.0.0
> postgis-1.3.3
> - I've also retried with postgresql 8.2 - just to check - and this works
> ok with the above script.  Unfortunately, I need the tsvector
> functionality that is provided by postgres 8.3.
> I can't see where this mismatch is coming in since it appears from other
> distros that postgis should be ok on postgres 8.3.
> Anyone have an idea what might be going on here?
> Many thanks,
> Calum
Hi Calum,
It sounds as if you have 2 PostgreSQL installations on your machine -
perhaps one installed as packages, and one compiled by hand. And it
seems the ./configure picked up the source headers for the wrong version...
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
