[postgis-users] PostGIS install on postgres 8.3 running on 64bit OpenSuse10.3
Calum Byrom calum.byrom at googlemail.com
Fri May 2 07:26:22 PDT 2008
All users that I might have used to do the install with have the same
pg_config results - which are:
BINDIR = /usr/bin
DOCDIR = /usr/share/doc/packages/postgresql
INCLUDEDIR = /usr/include/pgsql
PKGINCLUDEDIR = /usr/include/pgsql
INCLUDEDIR-SERVER = /usr/include/pgsql/server
LIBDIR = /usr/lib64
PKGLIBDIR = /usr/lib64/postgresql
LOCALEDIR = /usr/share/locale
MANDIR = /usr/share/man
SHAREDIR = /usr/share/postgresql
SYSCONFDIR = /usr/etc/postgresql
PGXS = /usr/lib64/postgresql/pgxs/src/makefiles/pgxs.mk
CONFIGURE = '--prefix=/usr' '--libdir=/usr/lib64' '--bindir=/usr/bin'
'--includedir=/usr/include/pgsql' '--datadir=/usr/share/postgresql'
'--mandir=/usr/share/man' '--with-docdir=/usr/share/doc/packages'
'--disable-rpath' '--enable-nls' '--enable-thread-safety'
'--enable-integer-datetimes' '--without-python' '--without-perl'
'--without-tcl' '--with-openssl' '--with-pam' '--with-krb5' '--with-gssapi'
'--with-ldap' '--with-libxml' '--with-libxslt'
'--with-system-tzdata=/usr/share/zoneinfo' 'CFLAGS=-fmessage-length=0 -Wall
-D_FORTIFY_SOURCE=2 -fstack-protector -O2 '
CC = gcc
CPPFLAGS = -D_GNU_SOURCE -I/usr/include/libxml2
CFLAGS = -fmessage-length=0 -Wall -D_FORTIFY_SOURCE=2 -fstack-protector -O2
-Wall -Wmissing-prototypes -Wpointer-arith -Winline
-Wdeclaration-after-statement -Wendif-labels -fno-strict-aliasing -fwrapv
CFLAGS_SL = -fpic
LDFLAGS =
LDFLAGS_SL =
LIBS = -lpgport -lxslt -lxml2 -lpam -lssl -lcrypto -lgssapi_krb5 -lz
-lreadline -lcrypt -ldl -lm
VERSION = PostgreSQL 8.3.1
- can you spot anything odd in there?
Thanks,
Calum.
On Fri, May 2, 2008 at 3:00 PM, Mark Cave-Ayland <
mark.cave-ayland at siriusit.co.uk> wrote:
> Calum Byrom wrote:
> > Hi Mark,
> > Thanks for the quick response.  I've tried what you suggested but to no
> > avail.  Observations whilst doing this:
> > i) If I install PostGIS from the unzipped source, via a ./configure,
> > gmake, sudo gmake install, the lwpostgis.sql, etc scripts get put in
> > /usr/share and contain unexpanded $libdir variables.  The liblwgeom files
> > end up under /usr/lib64/postgresql
> > ii) If I install PostGIS via the rpm, using the YaST2 GUI, the
> > lwpostgis.sql, etc scripts get put in /usr/share/postgis and the $libdir
> > variable they use is expanded to /usr/lib64 (although I don't think any
> > expansion is actually being done since the timestamp on these files is quite
> > old - so they're just being unpacked to this dir).  The liblwgeom files here
> > get unpacked this libdir - i.e. /usr/lib64
> > I've not done anything out of standard for any of the installs except
> > for configuring the postgres install using, LDFLAGS=-lstdc++ ./configure  -
> > as suggested in the setup guide I was following (see link in first mail).
> > Any other suggestions?
> > Thanks,
> > Calum.
> Hi Calum,
> What does the output of "pg_config" show? You should run this as the same
> user you ran configure. You may also try "which pg_config" to see from where
> configure is finding your PostgreSQL configuration information.
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080502/d9f220df/attachment.html>
