[postgis-users] PostGIS install on postgres 8.3 running on 64bit OpenSuse10.3
Calum Byrom calum.byrom at googlemail.com
Fri May 2 08:20:03 PDT 2008
This returns:
#define PG_VERSION "8.3.1"
#define PG_VERSION_NUM 80301
#define PG_VERSION_STR "PostgreSQL 8.3.1 on x86_64-unknown-linux-gnu,
compiled by GCC gcc (GCC) 4.2.1 (SUSE Linux)"
- which looks ok to me....
On Fri, May 2, 2008 at 3:53 PM, Mark Cave-Ayland <
mark.cave-ayland at siriusit.co.uk> wrote:
> Calum Byrom wrote:
> > Hi,
> > All users that I might have used to do the install with have the same
> > pg_config results - which are:
> > BINDIR = /usr/bin
> > DOCDIR = /usr/share/doc/packages/postgresql
> > INCLUDEDIR = /usr/include/pgsql
> > PKGINCLUDEDIR = /usr/include/pgsql
> > INCLUDEDIR-SERVER = /usr/include/pgsql/server
> > LIBDIR = /usr/lib64
> > PKGLIBDIR = /usr/lib64/postgresql
> > LOCALEDIR = /usr/share/locale
> > MANDIR = /usr/share/man
> > SHAREDIR = /usr/share/postgresql
> > SYSCONFDIR = /usr/etc/postgresql
> > PGXS = /usr/lib64/postgresql/pgxs/src/makefiles/pgxs.mk <http://pgxs.mk>
> > CONFIGURE = '--prefix=/usr' '--libdir=/usr/lib64' '--bindir=/usr/bin'
> > '--includedir=/usr/include/pgsql' '--datadir=/usr/share/postgresql'
> > '--mandir=/usr/share/man' '--with-docdir=/usr/share/doc/packages'
> > '--disable-rpath' '--enable-nls' '--enable-thread-safety'
> > '--enable-integer-datetimes' '--without-python' '--without-perl'
> > '--without-tcl' '--with-openssl' '--with-pam' '--with-krb5' '--with-gssapi'
> > '--with-ldap' '--with-libxml' '--with-libxslt'
> > '--with-system-tzdata=/usr/share/zoneinfo' 'CFLAGS=-fmessage-length=0 -Wall
> > -D_FORTIFY_SOURCE=2 -fstack-protector -O2 '
> > CC = gcc
> > CPPFLAGS = -D_GNU_SOURCE -I/usr/include/libxml2
> > CFLAGS = -fmessage-length=0 -Wall -D_FORTIFY_SOURCE=2 -fstack-protector
> > -O2  -Wall -Wmissing-prototypes -Wpointer-arith -Winline
> > -Wdeclaration-after-statement -Wendif-labels -fno-strict-aliasing -fwrapv
> > CFLAGS_SL = -fpic
> > LDFLAGS =
> > LDFLAGS_SL =
> > LIBS = -lpgport -lxslt -lxml2 -lpam -lssl -lcrypto -lgssapi_krb5 -lz
> > -lreadline -lcrypt -ldl -lm
> > VERSION = PostgreSQL 8.3.1
> > - can you spot anything odd in there?
> > Thanks,
> > Calum.
> Hi Calum,
> Apart from the strange libdir, everything looks good. The only other thing
> I can think of is a mismatch between the server version and the server
> headers (i.e. the postgresql-devel RPM still belongs to an older PostgreSQL
> version).
> What does "cat /usr/include/pgsql/pg_config.h | grep PG_VERSION" show?
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080502/1875e559/attachment.html>
