[postgis-users] ST_IntersectsPrepared
Paul Ramsey pramsey at cleverelephant.ca
Sun May 4 22:19:49 PDT 2008
Niels,
No, it's not in 1.3.3. The performance is indeed quite a bit better,
but it requires an unreleased version of GEOS and also still has a
memory leak in it somewhere... so definately going to be good stuff,
but not ready for release yet.
P
On Sun, May 4, 2008 at 9:15 PM, niels hoffmann <nielslcr at gmail.com> wrote:
> Hi List,
> Back in January, I asked about a large intersect operation. One of the
> suggestions was to use the ST_IntersectsPrepared rather than the normal
> ST_Intersects, which was at that time in development. I never got that to
> work before getting sucked in to some other project. Now I'm back on the
> intersect job.... So, I installed the 1.3.3 binary release on Postgres 8.3
> using the Stackbuilder and searched for the Prepared function but couldn't
> find it. Did it make the cut for the 1.3.3 release? I couldn't find anything
> about it in the release doco either?
> Cheers, Niels
> postgis-users mailing list
