[postgis-users] OpenJump
Chris Hermansen chris.hermansen at timberline.ca
Mon May 5 13:39:36 PDT 2008
I've had this kind of problem before when I haven't set up the role
correctly.  If you're working on a local (e.g. Linux) postgresql /
postgis instance using say PSQL you don't notice any problems, but if
you try to connect from another machine, you get frustration.
Make sure your role requires a password.
Matias Massigoge wrote:
> Hi Bob,
> I'have just try'd the DataStore connection with postgis and its
> working fine, if you want to try this i can show you my parameters.
> Good luck
> Matías
> On Mon, May 5, 2008 at 4:23 PM, George R. C. Silva
> <georger.silva at gmail.com> wrote:
>> Try:
>>  driver: postgis
>>  server:localhost
>>  instance: (public or the schema youre working on)
>>  user
>>  pass
>>  Att.
>>  George
>>  Bob Pawley escreveu:
>>> I'm having a problem connecting OpenJump to Postgis.
>>> I've installed OpenJump c/w the Postgis plugin running Postgresql 8.3 and
>> Postgis 1.2.
>>> The connection manager requires-
>>> Name - Database
>>> Driver - postgis
>>> Server - 8.3
>>> Instance - localhost
>>> User - postgres
>>> Password - *****
>>> The connection keeps getting refused. Am I giving the manager the correct
>> information?? The term 'instance' is unknown to me.
>>> Bob
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Regards,
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
