[postgis-users] question on returning area size using st_area.
Sidney Cadot sidney.cadot at jigsaw.nl
Tue May 6 07:36:27 PDT 2008
> Tells me that it wants the units to be in degrees?  So then, what is
> the 0.0174xx number there? Once again, I can only speculate, but I
> am assuming that perhaps this is a conversion to meters or some
> other standard unit at some point on the map (perhaps at the prime
> meridian).
It's the conversion factor to get from degrees to radians, i.e. Pi/180;
     angle_rad = angle_deg * 0.01745329251994328.
(actually it should be 0.01745329251994330 ...)
Hope this helps.
Sidney
