[postgis-users] Points with in multiple Polygons
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Tue May 6 10:12:14 PDT 2008
You want to run that command with the "-f" switch, the "-c" switch is
for a single command, not a script file.
HTH
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
chris brisendine
Sent: Tuesday, May 06, 2008 11:35 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Points with in multiple Polygons
Great Idea on the tornado intersect it does from time to time! It
worked great ! thanks, maybe one day it can save a life, If i wanted
to run the query from the command line would i use the  psql -c
run.psql to output a list to a txt file? im getting a error with that
ERROR:  syntax error at or near "run" at character 1
LINE 1: run.psql
Thanks alot your time is very appreciated!
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
