[postgis-users] Postgis License Clarification
Paul Ramsey pramsey at cleverelephant.ca
Tue May 6 12:25:23 PDT 2008
Client applications using the Java libraries are not subject to the
GPL, they are subject to the LGPL, so you can link to the JDBC client
and still use the code in a proprietary application. If you make
change to the JDBC code itself, those changes must be shared, but that
requirement is only for the changed PostGIS code, not for your own
client code.
On Tue, May 6, 2008 at 8:38 AM, Debasish Sahu <debasish.sahu at gmail.com> wrote:
> What are the restrictions imposed by the GPL license of Postgis ?
