[postgis-users] Updated shapefile to update postgres database
SenTnel elvin.pimentel at gmail.com
Wed May 7 14:55:22 PDT 2008
Thanks Regina, Chris and all of you for your help. Im truly newby but with
such help Im ready to start the procedures, Ill keep you posted of my
progress or else if some issue comes along that may require some light from
you, Thanks again and I hope my problem/solution may be of help to many
others,
Thanks again!
SenTnel wrote:
> Hello!
> I would like some help updating a postgres database. This is the problem:
> We created the database using shp2pgsql to convert a shapefile that
> contains a city's street details (centerline), after we created the
> database we also created an aditional column to classify the street types
> (eg: street, avenues, highways, etc.), now we are working on the original
> shapefile, updating new roads, changes made to highways due to
> constructions modifications, etc., and we want to upload the "updated"
> shapefile, without afecting the actual database, another words, we would
> like to convert to postgres the updated shapefile with the new information
> (it cuold be the whole shapefile) but to keep the added clasiffication
> column intact. How can we do that?
> Thanks
View this message in context: http://www.nabble.com/Updated-shapefile-to-update-postgres-database-tp17053562p17115477.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
