[postgis-users] Hibernate Spatial Postgis 3D
Drew Sheedy drew at olvec.net
Wed May 7 23:41:47 PDT 2008
Hiya Max,
But the WKTReader which provides you with the Point object to persist - does
not support 3D.
See the following:
       String wktPoint = "POINT(12 14 15)";
        WKTReader reader = new WKTReader();
        try {
            Point point = (Point) reader.read(wktPoint);
            System.out.println(point.toString());
        } catch (ParseException e) {
            e.printStackTrace();
The result will be: POINT (12 14)
HTH
Drew
On Thu, May 8, 2008 at 3:32 PM, Max <postgis at lists.meisel.cn> wrote:
> Hallo Drew,
> this is right, 3D support seems to be only in the SVN-Version, its
> Version 94 in the repository, should be from march this year.
> Max
> > Hiya Max,
> > Which version of the library are you using? It looks like 3D support is
> only in svn.
> > Drew
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080508/d31cd2dc/attachment.html>
